Gabriel píše:Dvoulitr je lehčí "jen" o cca 70 Kg proti NC soft-top:It's got more power – 155 horsepower and 148 pound-feet of torque from Mazda's 2.0-liter Skyactiv four-cylinder engine. But it's also heavier. Our car weighs 2,332 pounds, compared to the roughly 2,200 pounds of the 1.5-liter car.
Got a chance to ride (passenger) in a Club Edition ND (2016 MX5) today. Driver was an expert on one of our key suspension testing roads near the shop. Succinctly, the car feels like an NA with a built NB2 engine and 6 speed. This is all the grab by the scruff of the neck driving dynamics of the NA6 with whatever NVH improvements can be had 25 years later. The car has serious grunt down low. Unlike the NC which sorta died on top and the NA8 and NB2 which had good midrange but weak top end, the ND motor pulls eagerly with a very flat torque curve, just slightly softening in the last few hundred RPM. I'm told that's the OEM fuel cut strategy to save the cat, as opposed to an abrupt fuel cut that heats the cat. Flywheel felt really light. I don't know the weight but it felt nearly like an aftermarket flywheel, it revved so fast.
Car rotates around your chest, just like the NA, not your knees, like the NC. The drop throttle behavior is delicious, tucking the nose in, shifting weight forward and increasing yaw rate in a superbly progressive manner. The road we ran on is low to mid speed, lots of tight turns, very undulating and full of patches, lumps and mid turn bumps. The Bilsteins handled everything with aplomb, only when flat hammered through a transition and full bump did you feel it settle on the bump stops and gently, controllably rebound quickly. This all with a 180b driver and passenger. The car, like the NA, is intuitive and predictable right up to and past its limits.
The guy driving was using his fingertips, small steering angles, just on occasional correction. All the fun work was done with the pedals, as god intended. On a tight back road, this thing will destroy just about anything under about $150k on OEM tires.
The go kart is back
I'm so eager to get ours and start hoon.. er, R&D projects with it.
AndrewG píše:https://www.youtube.com/watch?v=2Lw6hkAztsc
(seatik, mal si počkať na to ND )
