KaCzaba píše:Neco takovyho...ale kde to hledat?
http://forum.miata.net/vb/showthread.php?t=247003 píše:take the retractor fuse out of the fuse box under the hood. Replace the fuse with a set of wires. put inline between the two terminals a switch, and the original amperage fuse. I have done this on my car. It is very hard to get the lights to exactly the proper place. I have kinda gotten the feel for it and can get the lights to approximately the same place after trying about 10 times. It is not easy by any means. The major hard part is pulling the wire through the firewall. I pulled mine through a grommet on the passenger . I had to remove the ac blower to get the wires through easily. this takes some serious finagling, but it is possible.
