Plati pre NA-NB-NBFL, ceny zhruba, v euro
HW
downipe,manifold,atd.........................................................500
pouzite TD04 z imprezy/forestera/garret/BorgWarner....................150-200/500-1500
repas sada na turbo.............................................................40+
intercooler kit...................................................................330
blow off..........................................................................od cca 50+
catch can, hadice, pcv z 323 turbo...........................................od cca 70-100
IAT senzor (napr.GM)...........................................................15
coolant reroute (v pripade NA/NB,neplati pre NBFL)...................cca 50
spojka............................................................................250-1000
chladic oleja ....................................................................150
vyfuk.............................................................................450
ecu ME221/MS2,3..............................................................700+
vstrekovace (denso z rx8,bosch ev14)..................................150-400
wideband lambda (LSU4.2/4.9) s ukazovatelom (vystup 0-5v).......130-250
NAMAPOVANIE
napr. len DIY+autotune (cena sw).....................................................50+
ladenie na brzde,nastavenie volnobehu atd + meranie vykonu................od cca 200-300
MOTOR
kovane ojnice.............................................................od cca 300-400
kovane piesty.............................................................od cca 400-500
piestne kruzky............................................,,,.............cca 50+
tesnenia,gufera atd.......................................................cca 40+
sviecky.....................................................................20+
Nejake naradie, montazny material cca (zavitniky,banjo bolts,vrtaky,srauby,tesnenia atd) ..............................od cca 40-200
olej, olejovy filter, vzduchovy filter, chladiaca kvap......................................................................................60-80
BRZDY
swap z NBFL sportive (270/276mm)............................od cca 600+ (v cene zaratane nove standard/oem kotuce a platnicky)
alebo willwood a pod.....................................................1000+
pancierove brzdove hadicky.............................................120-180
Plus praca alebo vlastny cas
Doporucene dalsie kompo:
LSD (v pripade NA nutnost vymeny polosi a kardanu)
podvozok
6 kvalt
pneu semislick
coils on plugs
polyuretanove silentbloky na podvozok
prerobenie ukazovatela oleja s kontrolkou nizkeho tlaku
ukazovatel teploty oleja
prerobenie ukazovatela teploty chlad. kvapaliny resp realny ukazovatel teploty chlad. kvapaliny
odlahceny zotrvacnik
al chladic
ATI damper
nejake tie vystuhy (frame rails,butterfly atd)
rollbar
atd, atd
