We fiddled with the cam gears on the street and on the dyno as well. These engines are not very sensitive to timing changes. Changing the cam and ignition timing yielded very little results. We advanced and retarded both the intake and exhaust cam quite a bit, but nothing significant changed. When we originally baselined the car it made 168 whp and 124 ft/lb's. We were however able to pick up a good chunk of mid-range power and settled with both the intake cam advanced about 6-7 degrees and the exhaust cam advanced about 3-4 degrees.
