Dodělání klimatizace
Re: Dodělání klimatizace
Příspěvekod AndrewG » 15 čer 2015, 21:28
hádam pomôže :-)
Has anyone installed a air conditioning system, and what parts need to be acquired to do this?
Yes-
Your car should be like mine, pretty much pre-wired and the ECU automatically adjusts idle.
Check the classified's, lots of people remove them for racing, to reduce weight, or make room for FI.(that's where I found mine)
Very straight forward and took less then 4 hours to complete
You will need:
OEM Switch(just the button) (I had to trade mine with Dan-O)
Compressor
Condensor
Lines high and low, pressure
Mount for compressor
OEM Electrical two relays (should be connected)
You will need to buy new
New Dryer
New Belt
Get system evac'd @ midas or other free shop.
6oz of oil
R134a (I think I used 2 cans)
Also this may not sound right but it worked...I added oil first and the compressor wouldn't kick over with the system empty(the clutch/compressor senses freon and will not engage without it) so I ran a orange 50' extension cord from the positive on my battery to the positive on the compressor(there is only one wire). the compressor kicked on, started circulating, and all was fine after that. (it was cold and snowy the day I installed mine so I wasn't in the right state of mind)
Quote:
Are the connections the same? The 90-93 AC were R12-based, and the 94+ systems are R134.
Stick with R134a and the 94+ systems. R12 is around $80.00 a pound.
http://forum.miata.net/vb/showthread.php?t=65911
možem potvrdiť že osobne mam všetky káble aj konektory od klímy v aute, napriek tomu že klímu moje auto nikdy nemalo...
Příspěvekod Mike » 16 čer 2015, 10:31
Děkuju za informace.
Obávám se, že to bude pěkná pakárna shánět ty věci. Ideálně kdyby někdo dělal z normální miaty auto na blbnutí a prodával to jako celek...to by se mi líbilo:)
Příspěvekod Tomik_84 » 04 črc 2015, 10:45
Mám rezervní komplet klimu z NB 2001. Domluva možná.
Tomik_84
Příspěvekod KarolKo » 12 črc 2015, 21:00
Tomik_84 píše:Mám rezervní komplet klimu z NB 2001. Domluva možná.
Měl bych zájem, pokud není prodaná. Cena?
KarolKo
Příspěvekod m8rinek » 12 črc 2015, 21:47
Já doufám, že spíš je :D.
Příspěvekod Tomik_84 » 13 črc 2015, 07:23
Ahoj, po prověřování jsem zjistil že část sady - klimakompresor, mám namontovaný stále na záložním motoru. Pokud ho oddělám, budu muset řešit zase další řemen. Momentálně plánuju předělání MP62 na svůj motor, takže klimakompresor bude volný a budu moct prodat celou sadu klimatizace, ale nyní potřebuji ještě čas. Jakmile budu hotový, ozvu se, díky za pochopení.
Tomik_84
Příspěvekod mcspeedyde » 16 črc 2015, 10:45
Potvrzuju, ze jsem hodne pred lety dodelaval klimu u 1.8 (107kW).
Vse je z vyroby pripravene - byla to plug&play prace.
Nejvetsi problem byla instalace vyparniku mezi vetrak a jednotku topeni. Je tam blbej pristup (pod kaslikem spolujezdce) a musi se trochu laborovat aby to sedelo a tesnilo. Jinak je tam misto vyparniku propojovaci plastovy tunylek.
Add elektrika - to byl nejmensi problem - kabelaz je pripravena a musely se jen zacvaknout 2 nova rele do predpripravenych konektoru (1x pro klima spojku a 1x pro druhy ventilator). A pak spinac A/C do palubky (opet zacvaknout jen misto zaslepky).
Dokonce potvrzuju ze u NBFL bylo mozne pouzit ram ventilatoru z NA vcetne druheho vetraku. Kdyz jsem to kupoval jako sadu - tak prave vetraky s drzakem chybely a tak sem na miste dokoupil co bylo k dispozici (a fungovalo to). Nebylo to z eBaye, ale normalne jsem to koupil v SRN na vrakovisti... :)
mcspeedyde
Příspěvekod Mike » 11 srp 2015, 10:18
Tomik_84
Až to bude volné, dej vědět...
Příspěvekod Johnie_Walker » 12 srp 2015, 11:27
nevíte někdo hmotnost náplně klimy u NBFL?
NBFL 1.8 Unplugged - Velocity Red
Johnie_Walker
Příspěvekod mojžo » 12 srp 2015, 14:28
0.6 kg. Chladivo R134A
Olej je ND-OIL9, norma SAE J639
