We don’t recommend the Miata specific Eibach Pro kit for Miatas as the spring rates are not adequate enough to keep the weight of a Miata from blowing through its available suspension travel. Since you have adjustable shocks that are able to handle higher spring rates, it would be a better match to choose something closer to rates that we use with our springs.
Muzzy píše:Psal jsem do Flyin´ Miata ohledne jejich pruzin, ktery planuju na auto a soucasti odpovedi byl i tento odstavec:We don’t recommend the Miata specific Eibach Pro kit for Miatas as the spring rates are not adequate enough to keep the weight of a Miata from blowing through its available suspension travel. Since you have adjustable shocks that are able to handle higher spring rates, it would be a better match to choose something closer to rates that we use with our springs.
Kdyz budu mit naldu, postnu to i nekam do adekvatniho tematu do technicke sekce pro blaho zdejsi komunity Kazdopadne me to utvrzuje v presvedceni, ze muj problem s odpruzenim byl zpusoben pro-kit pruzinami. Uvidime, jak to bude s novejma pruzinama. Zatim je to ale vzhledem k rozpracovanosti vsech casti v nedohlednu....... A ze na nejakou projizdku uz by se mi skoro chtelo
Winie píše:...
Muzzy píše:...jedna se o set na NB (tlumic, pruzina i ulozeni)...
Muzzy píše:...Leda by mx-5 popirala fyzikalni zakony a lehci NA stlacovalo pruziny na tezsi NB vic, nez bylo vyrobcem zamysleno...
Muzzy píše:Vazne si myslis, ze kdyz svuj podvozek tak jak je vezmu a dam na NB tak to bude fungovat jinak
Uživatelé procházející toto fórum: Google [Bot] a 52 návštevníků
